Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
what cam for stock 350?
Old 02-09-2008, 06:42 AM
Chevy_Stroke's Avatar
Default what cam for stock 350?
I just picked up a complete stock 350 out of a 65k mi 86 suburban carb to oil pan for $300. I am going to take the stroker out of my car and put the 350 in it and sell my car. im just going to go over the engine & replace a few gaskets
timing chain and cam. I would like it to have decent power and going with
stock look and less cash out I was going to leave stock intake and carb.
The car is a 1972 Caprice 4 Door with 700r4 2800 stall and shift kit and 373 posi in the rear.
Old 02-10-2008, 12:09 PM
EPP
EPP's Avatar
A Comp 260 camshaft would be a good camshaft to put in there.
HIGH ENERGY 260 DESCRIPTION: HYDRAULIC: Vans, pickups, 4WD & towing, in 350 c.i., good idle, strong mid range torque.
260H High Energy™ is the perfect cam for vans, family sedans, pickups and tow vehicles.
This cam provides exceptional power and a gas mileage increase, especially on the highway. With its great torque and throttle response, the 260H cam can also be used for O.E.M. replacement in most big block applications. The 260H’s idle is smooth in large engines with stock exhaust systems. With headers, the 260H will produce a slight exhaust sound.
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,200-5,200 RPM
Intake Duration at 050 inch Lift: 212
Exhaust Duration at 050 inch Lift: 212
Duration at 050 inch Lift: 212 int./212 exh.
Advertised Intake Duration: 260
Advertised Exhaust Duration: 260
Advertised Duration: 260 int./260 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.440
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.440
Valve Lift with Factory Rocker Arm Ratio: 0.440 int./0.440 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash (in): 0.000
Exhaust Valve Lash (in): 0.000
Grind Number: CS 260H-10
Computer Controlled: No
Lifters Included: Yes
Lifter Style: Hydraulic flat tappet
Valve Springs Included: No
Retainers Included: No
Locks Included: No
Valve Stem Seals Included: No
Timing Chain and Gears Included: No
Assembly Lubricant Included: Yes
Pushrods Included: No
Rocker Arms Included: No
Gaskets Included: No
I have set of Patriot Gold valvesprings and titanium retainers in stock, shown here.
http://www.exoticperformanceplus.com...html?item=1304 Bob
Old 02-11-2008, 11:55 PM
fireredz28's Avatar
anywhere from a .440 to .480 lift flat tapped hyd cam will give you good usable power just watch coil bind on the springs
Quick Reply: what cam for stock 350?
