Truck MAF to IAT. Is this correct?
I looked at a couple pin outs. I'm going speed density so I'm scrapping my MAF.
For the IAT its a 2 pin connector.
1- IAT signal source
2- Low reference
So can I take the Black Low reference wire from my 5 wire truck MAF harness and put that into the pin for Low reference on the 2 pin IAT plug? Then do the same with the TAN IAT signal source from the truck MAF?
Also, what IAT sensor are most guys running? The stock one just uses a rubber bung to seal, I can see that leaking under pressure.
Thanks for confirmation! I did search all over the site and couldn't come up with much aside from a couple wiring schematics.
2- Low reference
