Corvette Performance - Busted my rear-end...
Sprayed1998
02-09-2008, 05:22 PM
I was at HRP last night and on my 1st pass I tried to slip the clutch at 4500rpm and ended up snapping something in my rear. I called my mechanic and he said it was most likely the output shaft, he recommended a hardened shaft that cost $250. My only concern was that after it broke, I could put the car in any gear, let the clutch all the way out and nothing would happen. I would act as if it was still in nuetral. Is this normal for a car with a snapped output shaft? I looked under the car and the left side looks good but on the right side of the diff. there was fluid leaking out. Just wondering if anybody had a similar experience.
sultan(ZR-1)KSA
02-09-2008, 05:59 PM
lift it up and have a look u might have split the dif in half
racerrob333
02-09-2008, 06:19 PM
Yes most of the time thats normal when u bust the rear take it out send it back to dte and let them go threw and make sure u use harden shafts this time
Sprayed1998
02-09-2008, 07:31 PM
Just checking. I am 99% sure it is the right shaft, Im just gonna replace it with the hardened shaft and be done with it, I can live without going to the drag strip anyway. I am 24 years old and simply can't afford to repair this damn thing, lol.
2MuchRiceMakesMeSick
02-09-2008, 10:25 PM
One time when I was a kid, I fell out of a tree and busted my rear end also...
Usually you dont lose fluid when you break the shaft. Go look at the rear end case and see if it is cracked.
These differentials can get very expensive, im considering replacing mine with a 9"
mikep2002
02-09-2008, 10:40 PM
Thats the harder shaft of the 2 to break. Most people break the left(driver side) its longer than the right. Good Luck to you sorry for you misfortune and I think you may have broken the case also because of the leaking fluid.
Sprayed1998
02-09-2008, 11:00 PM
I sure hope not, I will know what is going on tomorrow hopefully when he gets a chance to look at it. I would have taken a look myself but I had it towed to his shop to avoid a 2nd tow and didn't have any tools/jacks with me. But while I was at the track I looked at it with a flashlight best I could and saw no cracks or holes in the housing. There was very little fluid coming out, not even enough to start a puddle, pretty much just leaked on the exhaust and thats it.
stainless40cal
02-10-2008, 05:14 AM
You mean as in a ford 9 inch read end???? I didnt know they made that conversion yet? If so let me know thanks...
V-seriesTech
02-10-2008, 08:36 AM
*leaking fluid.
You either cracked the diff housing, or the aluminum spacer between to diff and torque tube.
This COULD happen from breaking a shaft. Sucks to hear about your problem. Since, you say your on a budget, I suggest finding a junk yard...or seeing if someone in the vette world could help you out.
Best wishes dude.
Sprayed1998
02-10-2008, 12:37 PM
Well I hope it is just the shaft, don't they have seals that I could have busted causing it to leak a bit of fluid out of the right side? Like I said I could not see any cracks and I got a pretty good look at it, it is some sort of dyno-tech rear end, I assume it is a stage 1 going off the fact it couldn't take a 4.5 grand slip on nitto's, but I'm not 100% sure. I appreciate you guys suggestions, I've only had this car for 1.5 months and am new to the C5 IRS. But I'm gonna build it with both hardened output shafts as well as the brace, seems that is the main cause of the failures.
lionelc-5
02-10-2008, 02:36 PM
I recently replaced my rear with a 3.42 gear hardened ds shaft and a DTE brace.
I have the original out of my car, has about 20k miles on it. But it is a 2.73 gear in it. They do sell a 3.90 gear that will fit it.
It is out of an A4 car. Might not be what your looking for but i would sell it for 150 so it would be a cheap fix.
LionelC
O6DODGE
02-13-2008, 12:24 AM
so what are the results?
Sprayed1998
02-13-2008, 09:47 PM
Rind and Pinion are trashed, split the right side cover that the shaft goes in. The main case was in tact with no damage. I am swapping in a stock Z06 rear end with 3.42 gears and am gonna have them use my hardened left output shaft. Gonna cost me about $900-$1000 when it is all said and done.
BlownVette 2001
02-13-2008, 11:37 PM
If you're going to launch your car at 4500 rpm, you should consider throwing a brace on it. DTE also makes HD side cover for both the left and right side of the case to prevent what happened to yours.
sultan(ZR-1)KSA
02-14-2008, 02:07 AM
get your self a DTE brace
fastvet
02-14-2008, 09:41 AM
Hey sorry for the late post, but i had a simular expirience. i was at the track on my second run with 4.10 gears and the right output shaft broke during my burnout! it did what you said, it would go in gear and the rpm's and mph's would just go up and the the car would not move. when i had the 4.10 gears installed, i had them replace the left outputshaft, and not the right!
My advice to you, is do both sides now that you have it opened. or else you will end up like me and pay twice for that labor! When there is really no need to.
David Gordon
02-14-2008, 11:14 AM
Drag racing a Vette can be very expensive. I have broken 2 rear-ends and 2 output shafts. Wheel hop is a killer and will ussually break the tranny output shaft and take the rear-end with it.
Sprayed1998
02-14-2008, 06:52 PM
I aint racing it no more, not worth it.
1badzo
02-14-2008, 07:46 PM
i here ya but give it time you will be back out :nod:
BlownVette 2001
02-14-2008, 10:49 PM
Get yourself a Stage II Rear from RPM and a brace. You could go with the RPM C6 rear conversion for a C5.
The C6 rear has a bigger ring and pinion so you put less stress on them.
U LUZ
02-14-2008, 10:59 PM
PM me I will tell you what works...Belive me I have been there..
jdhommert
02-15-2008, 01:52 AM
send me a pm on whatever it is your talking about
Chris81
02-15-2008, 01:08 PM
Me too! lol
408zo6
02-15-2008, 01:30 PM
Me too! lol
x3:nod: i have a 02 zo6 with a 408... my car still drives fine but the diff is leaking on the P side i put a new seal in it and was fine for like 1,000mi and now itis doing the samething?
1badzo
02-15-2008, 05:46 PM
x4:D would like to know as well
OKcruising
02-15-2008, 06:41 PM
Or you could just call it a day at a dte stage 5 rear if you still want a IRS solution.
edit: if your wanting to sling a solid in the rear, then you need to re-prioritize the budget and methodology of the car. May as well just do a stg5 as a point of last resort.
you can budget a brace, or install some traction devices I imagine.
WhosNXT
02-15-2008, 06:42 PM
Oh I dont like this at all! I am in the boat with you brother, young and on a budget. I just got my Z, what happened to you is the reason I will not be at the track or launching hard on the street.
algws6
02-15-2008, 09:28 PM
pm me your secret!!!:secret2:
Sprayed1998
02-16-2008, 03:35 PM
PM me I will tell you what works...Belive me I have been there..Hey I already had Mike@ICON install a stock Z06 rear with 3.42 gears but I am interested either way, I'm sure down the road I will want to go back out to the track. Thanks bro.
O6DODGE
02-16-2008, 04:06 PM
Sent you a pm
mikep2002
02-16-2008, 08:36 PM
Lets just let the cat out of the bag on the big secret.....:secret2:
It would be nice to hear open opinions on it...
MPM IV
02-17-2008, 09:16 PM
I sent a PM as well.
