Fueling & Injection - Help Im A V4 Get Me Back To V8!!!!!!!!!
Rick. Salinas
02-09-2008, 09:59 PM
problem: cylinders 2 4 6 8 ar not working on my lS6
checked:
fuel.. perfect
spark.. perfect
spark plug wires.. good
coils.. good
plugs.. some burnt lookin due to backfires
background: ok i installed my ls6 into my 93 z. using painless performance harness.. the engine was working perfect .. then i had to drop the engine again to install diff rack and pinion.. put everything back.. then i got a back fire on cyl 6 and 8. switched plugs and wires to see if prob moved .. nothin..checked fuel.. spark.. compression.. all good.. then went o t disconnect injectors 2 4 6 8 and started car... started perfect of course only now with 4 cyl.. then reverse to the "bad" side... car wouldnt turn over..now half the engine dont work WTF!!!!... went to diagnose..i disconnected O2 to see if how it ran in both close and open loop.. same shit.. so now im down to wireing.. or ECM.. my ECM was flashed at G Force..but everything worked before so im not blamming them.. its an 02 ls6 timing should be good. but now im a 4 cyl .. i hate hondas.. some one GET ME BACK TO V8!!!!!!!!!!!!!!!!!!!!
Rick. Salinas
02-10-2008, 07:19 PM
Anybody???
LS1MCSS
02-17-2008, 09:47 AM
Have you checked the ground wires on the back of the head?
phoenix
02-23-2008, 11:44 AM
you have to be missing somehting on that right bank cylinder either spark or fuel
phoenix
02-23-2008, 11:46 AM
this sounds like its a wiring problem
