248/248 .590/.590 106???
is this close to being drivable??or tunable???
its a daytona prototype cam and the internals are gonna be callies 3.185 crank with 1.888 rod journals 6.500 lentz rods with a 3.905 bore
it equals a 5.0
i will also have stage 3 243 heads
port matched proffesional products intake
with a 90mm ported and polished throttle body
maybe i he told me the specs wrong but 106 lsa isnt that alot
it equals a 5.0
yea its solid roller to
im basically running dayton prototype internals so i think that can will go well with the set up
and yea itll sound so dam mean idleing
36 degrees of overlap in a 5.0L? A honda civic will have more torque than that thing. You'll need to run 12.5:1 compression for that cam to perform like it should, which will be hard to achieve unless you use dome pistons. It will be a real bitch to tune and it won't be close to drivable
that will not be driveably at all,and reducing cubic inches is not a good idea either.If you plan on turning 9k+ and have some really steep gears you may have a nice track car but it will def not be a street cruiser
i think they might be ls6 intakes heavily modified by wilson
i know a member on her has one he said he called wilson and they said they had about 1500$ worth of work done to them idk???
