LS1 harness/5.3 harness differences
Old 02-10-2008, 04:06 PM
91_RS_LS1's Avatar
Default LS1 harness/5.3 harness differences
Are there any major differences between the 99+ LS1 F-Body harness and the 5.3 truck harnesses? Would a 5.3 harness run the LS1 without modification? I've read that the injector plugs on the truck harnesses are different from the car motors and that the IAT and MAF sensor wiring is different. Thanks in advance!
Old 02-10-2008, 04:14 PM
jkwalkercchs's Avatar
im looking and im guessin they are considering people put fuel rails and injectors on the trucks and they just buy ls1 injectors
Old 02-10-2008, 04:16 PM
ls1nova71's Avatar
Looks like you answered your own question! Those are about the only real differences. Other small differences are extra pinouts for electric fans and smog stuff most people don't use anyway.
Old 02-10-2008, 04:34 PM
91_RS_LS1's Avatar
Question
So, I'll need to swap the injector plugs on the truck harness to car plugs before LS1 type injectors will work with the harness?
Old 02-10-2008, 04:47 PM
ls1nova71's Avatar
Thats right, somewhere I've seen adapters so you don't have to cut your harness, just don't remember where I saw them! Would also have to change the MAF connector, truck uses six pin connector with iIAT built in MAF car uses three pin connector and a seperate IAT plug.
Old 03-11-2008, 07:24 PM
tvrbo's Avatar
are the pcm pinouts different, or can you use a ls1 pcm with the 5.3 harness? anyone know a good place to locate one?
Quick Reply: LS1 harness/5.3 harness differences
