Heads and T-Rex cam ?
Old 02-10-2008, 08:31 PM
teddyls1's Avatar
Default Heads and T-Rex cam ?
Does anyone know how well these heads will work with a T-Rex cam?
new set of Patriot Performance stage 2 LS1 cylinder heads. These are based on 853 castings (they are center bolt valve covers). They are new and still in their original bags and packaging, which I did not remove to take pictures for fear of wearing off the protective coating applied to the parts. They feature 2.02/1.57 valves and 67cc combustion chambers.
5 Axis CNC Machined
21-4N Stainless Valves
Patriot Gold .650" Dual Springs
Titanium Retainers
5 Angle Valve Job
Asking $900 plus shipping
Stage II 1020 Superflow Bench 3.905 bore
Lift
2.02" Intake
1.57" Exhaust
.100
67 cfm
61 cfm
.200
133 cfm
108 cfm
.300
194 cfm
147 cfm
.400
242 cfm
183 cfm
.500
274 cfm
205 cfm
.550
290 cfm
213 cfm
.600
296 cfm
220 cfm
Old 04-04-2008, 09:53 AM
General Jack's Avatar
Bump... I have similar spec and flowing heads and the same question. Help is appreciated.
Old 04-04-2008, 10:28 AM
84z28Camaro's Avatar
While I can't give advice on the heads... I can say be weary of the seller, he seems a bit sketchy with no pics and the way he describes them.
Old 04-04-2008, 12:07 PM
phoenix1987's Avatar
If they are unmilled they should work. You will want to check PTV with the bigger valves though (should anyway) because the Trex barely clears stock heads.
