tt lq4 buildup Best cam/Intake manifold etc.ADvice please?
Old 02-11-2008, 01:59 AM
SonnyG's Avatar
Default tt lq4 buildup Best cam/Intake manifold etc.ADvice please?
Best cam for tt lq4 buildup....ADvice please?
I will be running two gt45 garrett ballbearing turboes and want 5-600whp
at no more than 12psi.....I also want something that I can later on up the boost if I want.....I really dont see the stock cam being good enough...But then again these lsx engines are sick,,,,,
Also what about fuel...throttlebody,head gasket etc.....Any suggestions will help...Thanx Guys....
Old 02-12-2008, 11:00 PM
gnx7's Avatar
Most people run a Z06 cam (perfect driveability and makes great power) and either the stock 5.3 intake/TB or an LS6 intake/TB will be the ticket. Both intakes have made 1000rwhp+ with this cam.
Old 02-15-2008, 08:06 PM
SonnyG's Avatar
Default z06 cam????????
Which cam do you mean a stock z06 cam?.......Do you have any specifics on that?duration lift etc?
Old 02-16-2008, 10:26 AM
OUTLAWZ RACING's Avatar
I think the 02 cam is tad smaller than the 04 zos cam. Its been proven many times. I thought about it but I run a epp cam. It has great mid to top power. As far as intakes I change to a vic jr and elbow because it has better air distrubtion to the the heads. Im not sure about power gains i havent read solid numbers yet. But the ls6 is bad *** also as far as the 90/90 fast i ran it was great to i think its just a matter of prefrence.
Quick Reply: tt lq4 buildup Best cam/Intake manifold etc.ADvice please?
