Oil Leak
Oil Leak
So, I've got a slight oil leak and don't really have a clue what's causing it, or exactly where it's coming from. I know it's coming from the front of the motor somewhere, and then it drips down and gets all over the bottom of the motor and there's also some on the tranny (Probably from wind from driving causing it to blow back onto it). Anyone know where it would be leaking at up front and what would cause it?
It could be your front cover, I believe there are three rubber gaskets that are a bitch to get in right. I remember that from the last time my opti was changed. Your valve cover gaskets could be leaking. If you have the normal LT1 intake leak you should see oil all over your starter, that's what mine did.
I think maybe it's the opti seal. The guy I bought it from had the opti replaced about a week or two before I bought the car. So, I'm thinking that maybe it wasn't sealed the best. It does look like it's coming from near the opti somewhere, and that's my best guess, as of now. I've got to take it in sometime to get an exhaust leak fixed, maybe I'll just have it checked out when I do that.
It could also be the water pump driveshaft seal in the timing cover. Mine was leaking like a ****. You'll more than likely have to get under the car with it running to determine where it's coming from. After replacing that seal, the opti seal and fixing the rear intake leak, I'm pretty sure my engine now has no leaks.
