1/2 qt. low within 3 to 4 weeks, is this normal?
Old 07-12-2003, 11:34 PM
9 Second Club NA
Dragaholic's Avatar
Default 1/2 qt. low within 3 to 4 weeks, is this normal?
Ive been noticing my car has been a little low when I check it and I was wondering if its normal or not? I just changed my oil maybe 3 or 4 weeks ago and checked it today and it was a 1/2 quart low. I put 5 all together when I changed it, could that be the reason? What do most of you put in it from the beginning? (when you change it) I run 5-30 Royal Purple. If me not putting enough oil from the start isnt the problem, why would it be low? The car doesnt leak, so what else could it be? Thanks
Old 07-12-2003, 11:46 PM
jmX
jmX's Avatar
Default Re: 1/2 qt. low within 3 to 4 weeks, is this normal?
A majority of LS1's burn some oil. Could be the PCV system (do a search), could just be oil getting past the rings.
So yes, its pretty normal.
Old 07-12-2003, 11:53 PM
Z06PSI's Avatar
Is it normal?? Absolutely mine got as bad as 2 quarts in 1500 miles... the smaller newer PCV valve helps...
Old 07-13-2003, 12:32 PM
9 Second Club NA
Dragaholic's Avatar
What do you mean by that? Did GM come out with another one to replace it? My car is a '00, did it come in the '01-'02? Is it a part that can be found at any parts store? Whats different about it from what mine came with? I just replaced mine maybe 2 or 3 months ago and I got it from Autozone and they looked identical. Thanks
Old 07-13-2003, 03:51 PM
trackbird's Avatar
My manual says that my 2002 holds 5.5 quarts with a filter change. I sounds like you don't have a problem. Did you check it after installing a new filter and 5 quarts (and running the motor to fill the filter)? Was it low? I think it should have been, I won't guarentee it.
I always use 6 quarts and a new filter and usually get 5-something quarts back out of it at 5000 miles. I'm running Mobile 1 10w-30. Just my thoughts.
Old 07-13-2003, 04:02 PM
glitch77's Avatar
Or... to say what Trackbird just said in laymans terms:
You should probably fill it up with oil if you want it to be full!
Old 07-13-2003, 05:43 PM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
Driving easy and turning low rpm, I can't ever tell that my LS1 uses any oil. However, if I drive hard, spin to 6,000+ a lot, it will suck down some oil. The more rpm the more oil burned.
Sometimes driving style effects oil consumtion too.
Old 07-13-2003, 08:41 PM
TT-TECH Veteran
Inspector12's Avatar
I am just like TRACKBIRD 6 quarts of oil (Mobil 1) and I ususally get @ 5 out depending on how I drove it Nice or Hard. I know you are saying how would you know if it is 5 after you change your oil but I buy the 5 quart containers and one extra and the old oil always fits in the 5 quart container real close to were it was when I bought it I then drop it off at walmart for disposal. Seeya!
