eXEDY sTAGE 3 aNY gOOD??
Is that clutch any good? I found one new for under 600 with flywheel slave and to bearing. I was about to get the exo-skel but this could save me about 800 total. Worht it?
http://www.lgmotorsports.com/catalog...oducts_id=1052 i have had a single exedy and i cureently have a exedy twin its pricey for the clutch but its a great clutch for drving daily and at the track most clutches or either or and then you have to wore about premature wear but depending on mods if your making over 430 hp i would go with twin but just depends on what your are doing with it. So far my twin has far outlasted my single plus the twin has way last pedal pressure its so little you think your clutch isn't engaging its very light effort but just pricey!
i had lg do mine and they said they do use any of the textralia clutches because of the chatter issue and with my single or twin i never heard any chatter. i personally think its a great clutch it just gets expensive here are the specs on there clutch. http://www.exedyusa.com/multimedia/s...vetteSpecs.pdf
Ive seen two exedy twin discs die with very little mileage on 500-600 hp cars. Those two peole told me they were big peieces of **** and not worth the money. I do not have any expereince with that clutch but to be safe im going text
lg motosrports only uses it on all builds from head and cam and big stroker and turbos! but it is expensive i only make 430-450ish to the wheels right now till i get heads then should get me over 500 hp
