"Larry" Pulley Install Problem
Old 07-13-2003, 12:27 PM
Xerxes's Avatar
Default "Larry" Pulley Install Problem
I went to install the "Larry" Pulley just a few seconds ago and when I went tighten, it was real tight. You could not spin it by hand at all at 5ft lbs (needs to be 37ft lbs!). I took it off and switched sides and got the same results. The back of the pulley is against the tension bracket itself causing it not to spin. I put my stock pulley back on and it spins very freely. This is the top tension pulley and not the bottom pulley correct? Could they have sent me the wrong pulley? Maybe I'm not doing something right...
Old 07-13-2003, 12:33 PM
98TAauto's Avatar
Default Re:
didnt the pulley come with a washer? I think(might be wrong) mine had a washer to give it more clearance, but its been 2-3 years since I put mine on. Maybe someone that just installed one would know
Old 07-13-2003, 12:52 PM
2xLS1's Avatar
Default Re:
Tou need to take a file or some sand papre and dress the casting flash on the aluminum tensioner. I had to do it on mine.
Old 07-13-2003, 12:57 PM
Xerxes's Avatar
Default Re:
Yeah, it came with the washer but it is too small for that. 2xLS1, that is what I'm going to have to do. It put it on the only way I could and started the engine and then turned it off. Took pully off and found that I had rub the paint off. So I'm going to take a file to the casting of the aluminum tensioner to dress it down like you said. Thanks guys!
Old 07-13-2003, 07:13 PM
DARK AGE 53's Avatar
Default Re:
The direction to installing the pulley should have told you that sometimes a little filing is necessary.
Al
Old 07-13-2003, 09:02 PM
Default Re:
Here's what my ASP ( Larry pulley ) instruction sheet says.
1. Remove belt from tensioner pulley.
2. Remove center bolt with 15mm socket. Standard right thread.
3. Install new tensioner pulley with snap ring facing towards radiator.
4. Install washer supplied with pulley inside snap ring.
5. Reinstall black factory cup washer and 15mm bolt.
6. Tighten bolt hand tight and check to see if pulley will turn freely. If not, light filing may be required on lower tensioner arm to remove excess cast, if built up. A rat tail file works well.
7. Tighten bolt. Check again to insure pulley turns freely.
8. Reinstall belt.
It doesn't say in the instructions but the torque spec for the pulley bolt is 37 ft/lbs.
Old 07-13-2003, 11:09 PM
Phil99TA's Avatar
Default Re:
i just picked one up too. Which side of the pulley does the supplied washer go on?
Old 07-14-2003, 03:30 AM
Default Re:
Read reply above.
Old 07-14-2003, 04:57 AM
Xerxes's Avatar
Default Re:
I didn't get any instructions with it what so ever. Thanks DARK AGE 53!
Old 07-14-2003, 09:02 AM
98TAauto's Avatar
Default Re:
doh, just remember I had to file a tad bit off mine... I cant remember things after a year LMAO
Old 07-14-2003, 09:28 AM
Larry's Avatar
Default Re:
I could have designed the pulley to fit without having to file the casting flash off but I didn't want to compromise strength.
Hope my pulley has eliminated belt walking problem for everybody that has bought it!
Old 07-14-2003, 02:36 PM
boos2's Avatar
Default Re:
Who is making these for you, Larry? Lee? or someone else? Just curious.
Old 07-15-2003, 01:14 PM
Larry's Avatar
Default Re:
Lee is handling this pulley now. You can buy them directly from ASP.
I had a group purchase after I tested my first pulley then gave the drawing to Lee.
Quick Reply: "Larry" Pulley Install Problem
