dcr, info
Old 02-12-2008, 12:28 PM
rpmauto's Avatar
Default dcr, info
what are all the figures i need to calculate drc. I have never done it before, and have always just figured scr. i dont know how far my pistons are out of the hole, if any and my cam is used (comp 238/240 at .050 605/609 lift.) Those are the only specs on the cam i have. I have a ls2 block (402) with the eagle crank, rods and je flattops (2cc valve releifs). I have not bought heads yet, i am still waiting for the engine to come back from the machine shop i took it to months ago. I made the mistake of saying that i wasnt in a hurry. I probably dont have enough info to calculate it, but tell me what i need. Thank you for any info.
Old 02-12-2008, 01:38 PM
5.3LJimmy's Avatar
Bore, stroke, connecting rod length, cam duration @ .006(aka advertised duration), lobe seperation angle, intake lobe center line, combustion chamber cc, head gasket thickness and bore, piston to deck clearance, and dish/dome or valve relief size of pistons.
Old 02-12-2008, 03:31 PM
rpmauto's Avatar
thank you for the info
Old 02-12-2008, 04:22 PM
405HP_Z06's Avatar
You also need to know the following to accurately calculate SCR and/or DCR:
1. Distance from the piston crown to top ring.
2. Diameter of piston above the top ring. This is typically .015 - .030 smaller than the bore diameter.
Many of the compression ratio calculators do not take these two factors into account; however, to accurately calculate compression these must be part of the calculation.
Old 02-13-2008, 12:03 PM
Bill Bowling's Avatar
Do you have this DCR Spreadsheet?
http://www.bowlingss.com/DownLoads/D...okup%20LS1.xls
Bill
Old 02-13-2008, 01:17 PM
rpmauto's Avatar
that spreadsheet would probalby be very handy, but my stupid computer wont let me download it.
