Carrier bearing install ?
Will a bearing press be required to install new bearings onto a new carrier if the carrier is in the 30's F & the bearings are heated to around 200-250 F, or will the bearings slide on w/ a little push? Thank-you
Detroil Locker True Trac
Use the right tool for the job, have them pressed on otherwise you will open the door for failure. Any machine shop should be able to press them on for about $20.00.
Jeff
Jeff
