plugs
That's not bad for the first time, sure you can do it quicker now. First time I did the drivers side one day, then waited to do the passenger side the next. Removing the air pipe and sliding the coil pack up helped a lot.
that's right on par with a first time plug change...i can do mine in under 30 minutes now.
of course i did remove my AIR system and only have two coil pack bracket bolts in place so it is much easier to reach. i also found the right ratchet/extension/socket combination to get the job done quicker
