how much of an improvement would I see from upgrading Shocks?
I have a basically stock ws6 right now and I was wondering how much of an improvement I would see by just upgrading shocks? I have the stock DeCarbons right now.
Also what type of shocks are the best...... for the price.
Go with the Konis if you have the $$$. the people who tell you they're not worth the money haven't ridden in a car with them. They have unlimited adjustment. You just keep turning a wheel to adjust them, so theres no actual # of settings. There is a full hard / full soft, but its unlimited in between. Call Sam Strano (sponsor) for the best advice you can get. -------------------------->
Ok, but the auto-x class only allows for two adjustments. Will the Koni's be legal?
Also, this is a little off topic, but the back end of my car seemed to be moving around a lot whe I went autocrossing. What would correct this, I was thinking tire pressure and a stronger panhard bar?
Buy Konis, your only regret will be you didn't do it sooner. It will be a whole new car.
[QUOTE=hpjunky98;8699637]Go with the Konis if you have the $$$. the people who tell you they're not worth the money haven't ridden in a car with them. They have unlimited adjustment. You just keep turning a wheel to adjust them, so theres no actual # of settings. There is a full hard / full soft, but its unlimited in between.
I agree koni's are the best and if you have the money you can't beat them. And to the question a panhard rod will make a world of difference.
I was also having a huge problem with busting loose around just about every corner. But Thats just a high powered rear wheel drive car right?
LS1TECH Sponsor
I sell both KYB's and Koni's (and others). I also autocross, very successfully and have results to back up what I do with the setups. I would be happy to help you to setup your car, we could even build a clone of mine if you like (I've won 2 of my 4 National Championships, and 2 of my 3 ProSolo Championships in my 2001 Camaro).
Koni's are what I use, they are better then AGX's, and shocks are not a good place to save money on a car really meant to work as well as it can. Will you see a difference with AGX's? Yes, but compared to what you have you'd see a difference with most any shock. But you won't get the damping ability and overall polished damping the Koni's give you.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Where would you start if you wanted your car to handle better? My car is completely stock right now. I have also heard a "performance allignment" is a good place to start.
LS1TECH Sponsor
I don't really recall what the car is, or what you have done. I'd recommend staring with an F-stock legal car, which is MUCH cheaper to setup (really only shocks and a front bar along with the tires). And you can build on to that, which is what I did with my car. Moved from FS to ESP.
You won't like it, but the shocks are the most major problem with the car so that's where I always start. I don't consider an alignment so much of a mod because all cars need them no matter the use. It does help, but the major issues as you drive the car down the road aren't alignment based. Shocks first, bar (front only for FS, or both for ESP cars), springs, PHB are the next items up. Though if you can swing shocks and springs at the same time it's only smart to do them together to save some installation costs.
__________________
