Ported 98' oil pump.. Have a question
Old 02-13-2008, 07:52 PM
vetteboyc5's Avatar
Default Ported 98' oil pump.. Have a question
My LS1 spun a rod bearing.. Im not too sure of the causes but Im rebuilding the motor right now..
I disassembled the pump and inspected everything looks great, rotors and all.
I Desided that there was not a significant difference in the ls6 pump. I fully ported out the intake port and the outlet port and greatly increased their ports volume.
And I shimmed the pump with a 1/8th shim per article on LS1 tech.
Ive read about the early LS1 having oil issues.. Mine is a 98 engine.. though even with the rod spun rod bearing it was still having 15-19 Psi At idle hot..
Whats the common failures, The check valves?
With my above said mods, can I still run this pump? Its clean and ready to go if so.
Old 02-13-2008, 08:00 PM
kwiksilverz28's Avatar
That is low oil pressure. Honestly, I would switch to the Melling 296 and be sure
Old 02-13-2008, 08:59 PM
SOMbitch's Avatar
Strongly agree.... why risk a rebuilt motor over $125 part.
Old 02-13-2008, 10:27 PM
SS#1531's Avatar
I wouldn't risk it either. I went with the LS6 ported and shimmed pump when I did my cam swap. The extra insurance is worth the piece of mind.
Old 02-13-2008, 11:00 PM
01 BERGER CAMARO SS's Avatar
me either, get a melling or tsp. Id rather spend another 120-150 then another rebuild
Old 02-14-2008, 04:00 AM
stevied916's Avatar
just change it. It's not even worth your time messing with that one
