FS: TA HID lights/ballasts and stealth sub box/sub/amp
Old 02-14-2008, 01:59 PM
Donohue96M6Z28's Avatar
Default FS: TA HID lights/ballasts and stealth sub box/sub/amp
The HID lightbults are 8000k and come with the housing. Also comes with the ballasts, but I believe one of the ballasts is bad. I know someone that will sell 2 of the same ballasts for $50 for the pair.
$150.
The sub box is in great shape, the sub is a 10in orion sub that stopped working for some reason? it still moves with the bass, but seems weak. the amp is a phonix gold octane r2.5:2.
sorry dont have pics of the sub/amp.
100 for all, wont split.
Old 02-14-2008, 02:00 PM
JMBLOWNWS6's Avatar
Pics of the hids.
Old 02-14-2008, 02:02 PM
heres a pic of them on the car...
http://i17.photobucket.com/albums/b8...%20am/HIDs.jpg
Old 02-14-2008, 02:07 PM
JMBLOWNWS6's Avatar
So these are REAL housings and not some cheap retro **** correct? One of them doesnt work at all or not all the time?
Old 02-14-2008, 02:35 PM
ya these are the real housing, and heres the problem that I was having...
I noticed the drivers side flickering sometimes/not staying on, I thought maybe it was a bad bulb?, but no, I took the passenger side light off and hooked it up to the drivers side ballast and it had the same problem. I then took the drivers side light off and hooked it up to the passenger side ballast, and it worked now. So that tells me the bulbs are good. and the drivers side ballast is bad.
Old 02-14-2008, 02:47 PM
JMBLOWNWS6's Avatar
Is this a high and low beam kit? Im temped
Old 02-14-2008, 02:50 PM
Just low beam, come get them , im only a few minutes from LP off 3009. Or i'll deliver to LP and you can check out my blinkers
Old 02-14-2008, 02:54 PM
JMBLOWNWS6's Avatar
I want a dual kit. Your blinkers are a easy fix man. EASY! Check the front ones first. If they show bad signs of being burnt go get some contact cleaner and clean them up. Then get some dielectric grease. That will take care of the problem for a while
heres where they were bought from...
http://ledgauges.net/catalog/product...59582af04c7cb8
Old 02-14-2008, 02:56 PM
dont think thats the package tho^^ not sure.
whats a dial kit?
Old 02-14-2008, 02:57 PM
JMBLOWNWS6's Avatar
Edit FTW!
Old 02-14-2008, 02:59 PM
LOL, how does that dual kit work... are they in the same housing, or in seperate housings?
Old 02-14-2008, 03:01 PM
JMBLOWNWS6's Avatar
Well the kit I ordered for my 04 cobra has them in the same housing. I would like a low beam kit and a high beam kit. Thats a badass kit you have but Im looking for something a little different. Still a dam good deal!
Old 02-14-2008, 03:03 PM
, ask around at the shop bro. These have just been sitting in the garage for the last 2 months.
Old 02-14-2008, 03:07 PM
neodamonkey's Avatar
Willing to sell the housing seperate?
Old 02-14-2008, 03:36 PM
make an offer if interested in them. but i'd prefer to keep together.
Old 02-14-2008, 03:49 PM
JMBLOWNWS6's Avatar
Ill give you $75 for everything and fix your blinkers!
Old 02-14-2008, 04:07 PM
Blue 98 Ram Air's Avatar
Ill take the sub amp and box. Ill pm you tonight.
Old 02-14-2008, 04:27 PM
blue00WS6's Avatar
with the t/a's having seperate housings for the high beams and low beams you have to get a sealed beam conversion. it allows you to change the bulbs to whatever you want. you can still purchase the hid kit since it is complete with housings/hid's and then buy seperate housings for your high beams and then put whatever bulbs you want in there.
Old 02-15-2008, 12:03 PM
bump.
