STS turbo on a lowered car?
alright, i started my new job, with it comes the fun new job stuff. more opportunity, more money, fresh starts, and more importantly, room in my budget for a turbo.
i have a lowered 2000 trans am and ive been lookin at the sts turbo kits. I was wondering if i could hear back from anyone that has these on a lowered setup, i want to know about lag, bottom out issues, and sucking in water. it seems like that would be a risk with the air intake back there.
any problems i wanna know about, cuz its kind of a big investment to leave on the side of the road if you know what i mean
Mine's lowered. The two lowest points in the system are the pipe under the k-member and the pipe under the driver's side rear lca. Depends on what you're willing to drive around instead of over. Right now my car won't go over a speed bump. The front pipe will ride up with the front wheels, but the rear one will hit before the tire goes up.
Also if I have a flat tire, the pipe will probably be on the ground.
I have a shield around the filter and it should block most of the spray. That's independent of being lowered though.
Last edited by John_D.; 02-19-2008 at 09:42 AM. Reason: the second b in "probably" had disappeared somehow... I don't talk like that. Really. No really. :)
your lowest pipe will be at the rear of the car where the pipe over the axle mates with the subframe pipe that attaches to the chassis. also a low spot will be where the pipe turns to go up towards the engine
the rear pipe (After over the axle) can be adjusted by about 2inches
I'm eventually going to run my front pipe up between the engine and the k-member. There's barely enough room to do this, and only because I switched to solid engine mounts. There wouldn't be enough space with stock mounts.
I got a little more clearance with the rear pipe when I changed over to aluminum rod-ended lca's instead of the stock u-channel ones. I also modified the rear end of the STS supplied rocker panel pipe so that now I'm crossing under the lca closer to the lca pivot at the body end, and I don't get quite as much lca movement at that point.
^^thanks for that. if i had found the specific answer i wanted in the search, do you think that i would have posted a new thread....
to the rest of you though, thank you and i appreciate your input. ive decided on a twin turbo setup, so the sts kit isnt getting bought.
Smart move! Bob
No offense to those running an STS kit, but on an F-body there's just a lot of drawbacks to both the design and the execution. If I were to go turbo, I'd look at TTi and APS setups.
As I was reading the thread, I was debating posting "don't buy it, go with a different setup". Now that you have, I can definitely post.
its nothing personal with you sorry, just tired after three years of constant mis-informed people making judgements about rear mount kits. the only point i was trying to make was all kits have problems , none come as a bolt on no problem kit. Prochargers overheat, Front mount turbos usually lose A/C , STS has an oil return, APS hangs to low, etc etc. all of us that have chosen Forced Induction have had to make mods to our cars for the kit to reach its potential.
No argument here. Have yet to find the "perfect" kit with zero flaws, drawbacks, or compromises. I guess I would say I prefer some kits over STS as the lesser of the evils so to speak.
