Removing water spots from windows?
Old 02-15-2008, 12:10 PM
NewCar's Avatar
Question Removing water spots from windows?
I had to do this on my old Mustang. I have to do it again on this one. I'd really like to find a better product out there if there is one. I forget the name (I'm at work), but I use steel wool & this white liquid stuff. I had to use a lot of elbow grease & ended up with marks on the windows even though I used the finest steel wool out there.
So what products are on the market to remove waterspots? These bitches are baked on!
Old 02-15-2008, 12:27 PM
xBROKEx's Avatar
i used simple green and some steel wool
Old 02-15-2008, 01:35 PM
SIC LSX's Avatar
the steel wool will come in different grades! I have always used grade 0000 with some liquid metal polish try it on a small part 1st to make sureeverything is ok 1st. Dont just use any steel wool or you will scratch the **** out of the glass.
Old 02-15-2008, 01:57 PM
RickyMartinZ28's Avatar
0000 steel wool and chrome polish
do it lightly, don't scratch it
Then keep some rain-x on the glass and it shouldn't happen again.
-Rick
Old 02-15-2008, 02:59 PM
SStealth00's Avatar
i used a razor blade
Old 02-15-2008, 04:56 PM
junior28570's Avatar
I had BAD hard water spots on my truck windows .. I used 3M "fine polishing compound" and a brillo pad .. It wasn't easy but I learned something .. NEVER let water spots go .. they only get worse!!!!
Old 02-15-2008, 06:44 PM
SIC LSX's Avatar
When i lived in Hawaii water spots are very bad and i did about 300 cars the 3 years i lived there and all of them looked like new glass when i got done. Never once left a scratch.
Old 02-15-2008, 11:18 PM
zlover129's Avatar
razor blade and glass cleaner
Old 03-11-2008, 09:21 AM
brapril714's Avatar
I just did this last night, chrome polish and microfiber towels. Oh yeah, don't forget your wheatie's. After that I used some Meguiars plastic polish to clean up. Here's a pic of the passenger side not done and the driverside finished.
Old 03-11-2008, 05:10 PM
Breathtaker's Avatar
Polish your windows, that's what I did and came out great.
Old 03-11-2008, 06:22 PM
camaro-94-z28's Avatar
i used glass scrub and a buffer
Old 03-11-2008, 09:13 PM
blackops22's Avatar
Zaino X Glass Cleaner -- It's the only stuff that I have seen work. I put some on my buffer and buffed them all out really fast.
Old 03-12-2008, 12:13 AM
Stangkilr's Avatar
wheel cleaner and compound, mix them two together and you have yourself a badass acid rain remover.
Quick Reply: Removing water spots from windows?
