Need 00-02 WS6 passenger side door panel.. Black interior
My passenger side door panel has a slight crack in it.
I talked to the dealer and this was there response..
"Since its winter and you probably have the heat on in your car the plastic will expand. When you turn off your car and shut the door, if the window is cracked even the slightest bit the cold air will get in and then the door will contract because its plastic. The expanding and contracting of plastic on the door panel over time might cause it to crack."
How ******* cheap.....
