Cam for stock heads
Old 02-15-2008, 03:25 PM
LS1Z28_98's Avatar
Default Cam for stock heads
I was wondering what the absolute most agressive cam is that I can put in a 98 LS1 with stock heads.
The car has an LS6 intake, LT headers, and is an M6.
I have already went out and bought a set of Patriot Gold springs to go onthe heads.
Curious of what cam specs stock heads can handle.
Any and all input is appreciated.
Old 02-15-2008, 07:35 PM
ls1pwrdss's Avatar
ms4 from texas speed
t rex from thunder racing
vindicator from vengance
Old 02-15-2008, 09:23 PM
silverbullitLS1's Avatar
i have stock heads and i went with the torquer v3 cam 643/598 lift with dual valve springs.
Old 02-15-2008, 09:28 PM
RedRallyeZ's Avatar
not MOST aggressive by any means, but has a great power curve for stock heads, and will drive alot better is tr230....
just chiming in for the small cam crowd....
Old 02-16-2008, 12:40 AM
firefighting1101's Avatar
i like the trak cam and predator z helped me out with a cam for stock heads...said they mde 430 with full bolt ons...specs at .050 lift 230/230, .612/.592 111+2 LSA
Comp Cam lobes
Intake XFI lobe # 3016
Exhaust XE-R lobe # 3725
LSA 111
ICL 109
Old 02-16-2008, 06:43 AM
LS1Z28_98's Avatar
Thanks all. Trust me this car is not a DD. I think I put 1200 miles on it last year, so drivability is not a factor at all. Actually the more lope the better in my eyes!!!!!
Old 02-16-2008, 06:22 PM
418redz28's Avatar
T-REX then all the way
Old 02-16-2008, 06:29 PM
blackthunder's Avatar
ms3 and I have one for sale
Old 02-18-2008, 07:50 AM
LS1Z28_98's Avatar
LOL well an aside on another project......How about stroked then blown???
SBC 383 with a 671 blower?
Old 02-18-2008, 05:38 PM
SSstud's Avatar
alright guys...im looking to go cam only. ive been looking at the ms4 for quite some time now, so close that im searching around forums for people selling the cam. i recently came across the vindicator and i see and read that they are pretty dam similar cams when it comes to specs. the SS is not a daily driver, driven only in the summer. saying i want to put the biggest cam possible seems somewhat ignorant, but i want to put in a big cam nevertheless. the more i read the more i find descrepancies so i was wondering if anyone could give me some difinitive answers on what cam to pick, and this is WITHOUT having to flycut the pistons as you guys may have already figured...thankxxx
Old 02-18-2008, 05:44 PM
overkill-lt1's Avatar
how much??
Old 02-18-2008, 06:07 PM
boola1341's Avatar
Dumb question????? To install a cam does the motor have to be pulled out of the car???
Old 02-18-2008, 07:40 PM
SSstud's Avatar
motor definitely does not need to be pulled out of the car...
Old 02-18-2008, 08:10 PM
hammertime's Avatar
Buyer beware - most cams of that calibre end at, or just less than the safe recommended minimum clearance. Most agree that .080" Int. .100" exhaust is the least you should run, and possibly more on a hydraulic roller manual trans car that has a heavy valve train the the possibility of a mechanical overev.
In a nutshell, running a big cam for the sake of having a big cam just doesn't make sense. You will likely get similar performance from a slightly smaller cam and not lose any of the benefit. If you insist on running a cam that large, at least measure, rather than take someone's word it will fit. Too many variables to leave it to chance.
Old 02-18-2008, 09:40 PM
alamantia's Avatar
when I contacted thunder racing with the same exact question they suggested the 224/224-112
Old 02-18-2008, 09:43 PM
shift123's Avatar
Check out the fastest cam only cars in the drag racing section.
Old 02-19-2008, 05:45 PM
Shawn MacAnanny's Avatar
Lol you dont need one with as high lift as mine. Everyone says measure PTVC, measure PTVC, measure PTVC. I say if i gotta remove my heads to flycut my pistons I'll do it for a nice set of ported heads that i bought because my valves started hitting my pistons . A set of stock 241s is worth what, $200? That's about what gaskets and bolts cost to check PTVC so really it's just a toss up. I'm a risk taker. I say go with the Trex if you want a proven, mean sounding cam that you can rev the hell out of. That's what i was orgionally going to go with.
Old 02-19-2008, 05:48 PM
EHat911's Avatar
another one for the TSP MS4 and MS3
Old 02-19-2008, 06:40 PM
Fastback302's Avatar
I know the specs are very close between the MS4 and MS3...but with typically 5 less horsepower from the MS3 is it a lot safer and not so "on the edge"! Do to the specs being 603 instead of 649 on the intake!
Old 04-09-2008, 06:31 PM
tkimrey's Avatar
TSP Torquer v3 here on stock heads (but not for long) and it's everything I wanted out of a cam.
