Gears & Axles - Those who have done the drill mod...HELP!
BillWS6Formula
02-14-2003, 11:55 AM
I have a SPEC III clutch waiting to go in and I just received the new GM master cylinder I'll be putting in too. I read the link on directions on how to do the drill mod from a search here, but the fitting on the end of the braided line section has me scratching my head. According to what I read, the "obstruction" is located about 1 inch inside from the end of that braided line. But there's this fitting *L* that...well just look at the pics, the third one in particular and you'll see what I mean...how to drill out the obstruction inside if this is in the way? Or am I completely off base here?! *L*
<img src="http://atlas.imagemagician.com/images/ws6/Mastercylx001.jpg" alt=" - " />
<img src="http://atlas.imagemagician.com/images/ws6/Mastercylx002.jpg" alt=" - " />
As you can see, there is nowhere to insert a drill bit!
<img src="http://atlas.imagemagician.com/images/ws6/Mastercylx003.jpg" alt=" - " />
Rayo
02-14-2003, 01:50 PM
The obstruction is found at the other end of the line...at the bottom of the MC...where the line goes in...you should see a role pin...I used a very thin phillips screw driver and hammer to hammer it out...lightly...then you drill that end of the line...check this site out...
http://installuniversity.com/install_university/installu_pages/sophomore_year/drill_master_cylinder.htm
Got to step 15...figure 14...you'll see what I am talking about...
Rayo
BillWS6Formula
02-14-2003, 02:16 PM
Hey, those are better instructions than the ones I was using, thanks!!! Gotta love pics *L*! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
