Clutch Install help needed asap!!
After I put the flywheel on the crank snout (?) it sticks out too far and wont allow the clutch to sit flat against it. The clutch is hitting the crank end, and yes I have the clutch the right way. Crank is an Eagle 4" and I compaired it to stock and the end is quite abit longer. Clutch is new LS7.
