looking for a quiet bypass valve
Old 02-16-2008, 12:32 AM
lmt0705's Avatar
Default looking for a quiet bypass valve
im not sure if I can still use my stock procharger bypass valve or not for a high boost app. if not what are you guys running and how do they sound, im looking for something quiet.
Old 02-16-2008, 01:57 AM
Drew04GTO's Avatar
Greddy type R recirc'd to compressor inlet! Anything really that is fairly large that you can attach a hose to so you can dump it back into your compressor inlet. I advocate not being a ricer, plus not loosing as much boost between gears is always a plus.
Old 02-16-2008, 03:08 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
I know you can add an air filter to the Mondo Bypass valve. That quiets it down.
Old 02-16-2008, 03:14 AM
DeltaT's Avatar
I never hear my Mondo. At all. I have it set up to dump directly back into the Vortech inlet adapter. I know it's opening and closing when it should, but it doesn't make a sound.
Jim
Old 02-16-2008, 08:12 AM
lmt0705's Avatar
how much is this mondo bypass valve? Im going to be running Bobs fmic, will I be able to dump it back into the compressor inlet?
Old 02-16-2008, 08:13 AM
lmt0705's Avatar
do you think I can still use my stock one?
Old 02-16-2008, 11:40 AM
9silverbird8's Avatar
I use my stock one up to 10 psi, never hear the thing. How much boost is 'high boost'?
Old 02-16-2008, 12:16 PM
lmt0705's Avatar
Old 02-16-2008, 02:05 PM
Black_Jack's Avatar
just get a recerculated bov there pretty quite
Old 02-16-2008, 04:18 PM
DeltaT's Avatar
No you can't use your stock bypass for 16-18psi. You will need a Mondo or something in a similar size. Maybe get by with the next size down, but why risk it?
Jim
Old 02-16-2008, 08:30 PM
mikep2002's Avatar
I thought the greddy valve where BOV and where not good for the bearings on a supercharger? I am also looking to upgrade my setup and I think the Mondo is to large for my app. and the procharger race bypass is just huge....
I want something that vents alot I missed 2 shifts both times I tossed the belt and heard a rumor the impeller does funny things when you goof? Something along lines of needs to vent alot for goof ups. I dont know how true that is?
Old 02-16-2008, 09:25 PM
barnat's Avatar
Default Bosch
Ive got 2 brand new ones from my APS kit that may work for you There the Bosch Type recercultory
Old 02-17-2008, 08:39 AM
lmt0705's Avatar
is that the same thing I have from my origional procharger kit?
Old 02-17-2008, 08:55 AM
EPP
EPP's Avatar
I would use the ATI Race Valve and it has an option to recirculate.
http://www.exoticperformanceplus.com...html?item=1261 Bob
Old 02-17-2008, 09:06 AM
lmt0705's Avatar
how do you recirculate it? do you run a hose from the valve back to the blower hat? what if I dont use the stock hat? how did the show go yesterday?
Old 02-17-2008, 10:14 AM
EPP
EPP's Avatar
You can weld a bung into the tubing to recirculate it.
The show is still going on today, very few vendors and very few people attending the show. Bob
Quick Reply: looking for a quiet bypass valve
