Question about Cloyes timing chain
To run a Cloyes timing chain I would have to convert to a EWP, remove the waterpump drive, and remove the CPS reluctor. Is that all that needs to be done for clearencing for a 96 camaro?
Also, on the summitracing web site, they list 4 different chains; CLO-9-3145, CLO-9-3145-10, CLO-9-3145-5, and CLO-9-3145-15. Which one would I want to use?
This is the timing chain I was thinking of using.
http://store.summitracing.com/partde...5&autoview=sku
9-Second Club
http://www.sdparts.com/product/SDCS1...TimingSet.aspx
Check out this one at Scoggin Dickey, it is what I use. Nices piece, and clears my covers just fine.
Ed,
That is a nice looking piece for a very reasonable price. I have been looking for a good DBL-roller that I can just plug & play. It looks like your saying the unit does not require any additional work with the stock 96/97 timing cover. I don't want to modify my cover, just want to install it and go
I installed the same cloyes set on mine ( 95 LT1) and i had to modify my cover ...
tried without gasket : no clearance
tried with two gaskets : still no clearance
I had to grind down all the cover reinforcement that is around the opti hole so that the cam gear section would clear .... now i have around .045 clearance ...better be safe then sorry!
Dan
Dan
9-Second Club
Both of mine have 1996/1997 timing covers, no clearance problems with either. Cleared with no gasket before assembly. The 383" has been run three or four years, the 355" all last summer. Have them both apart right now, no problems. If anything ever touched it would be evident. Maybe the OBD2 cover has more room? Don't own an OBD1 cover, so can't say.
9-Second Club
Ed,
