oh snap, carnage pics inside!!
so a few buddies and i decided today we would pull the engine in the camaro.
pulled it out the top and found this inside
BALLSSSSSS. anyone know a good company for fixing heads ? i really cant afford new ones.
this is gonna get pricy really quick, as i see it i need the head repaired, new pistons and the neccessary rebuild parts (bearings gaskets etc.) the cylinder wall looks ok, btw this is cyl #7. woe is me
its been smoking for a while now, and yes , i launched from a light and a horrible noise followed kinda like a broken lifter noise but deeper and louder
Weisco, JE, Diamond then Mahle.
That being said, I just had my motor rebuilt with Mahle pistons. And both my mechanic and machine shop have nothing but good things to say about them.
talk to me about pistons, whats with the dish style and flat top, explain im kind of a newb at internals. what should i be looking for, i intend to spray quite a bit later, but the car is also driven every nice day i can. what do i need to know about pistons and what the differences are?
Damn that sucks. I know this sounds retarded but I hope something happens to my engine so I can forge it. I will never spend the money otherwise and since the engine will be out I will be more motivated and the Fiancee would understand more then lol.
The wedding will be put off baby until I forge my engine since its a priority with all my money...think that will work?
Good luck getting it back together.
Go with Mahle. Thunder racing sells them. you are running flat tops with valve reliefs. They will probably have 2 choices for the depth of the fly cutting, for safety sake i would get the deepest ones and be sure you have piston to valve clearance so you stay away from as many problems as possible. They have an some dual coating process and my engine builder also recommended them for my 347 build which is almost done.
Two common causes for a failed ringland on a good piston (and Diamond makes very good pistons) are:
1.) Ring end-gap set too tight, ends butt together at operating temp.
2.) Excessively lean fuel:air mix. Looking at the adjacent head chamber, that one appears to be slightly rich...whereas your failed chamber and piston crown show slightly lean burn conditions. Partially obstructed injector maybe?
