front koni install help
i have the front and rears installed with bmr springs, the rear is fine but the front doesnt seem to have much suspension travel, even set at full soft, is it normal for the top chrome adjuster plate to be resting right at the bump stop on the strut mont.
Sounds like you installed lowering springs on the perch meant for lowering with stock springs. There are 2 perches on the shock tube, one for lowering springs, and one for lowering the car on stock springs.
