Summit 2500 dampener or asp
Old 02-17-2008, 02:20 AM
js2fst's Avatar
Default Summit 2500 dampener or asp
Do I need the ati balancer for a 8 rib procharger d-1? do I need to pin these? These seem to be alot less expensive. $150
Old 02-17-2008, 07:39 AM
EPP
EPP's Avatar
Yes, the ATI Performance Products balancer is the only balancer that the ProCharger bolt on crank pulley will seat against and is also the only balancer that the ProCharger bolt on crank pulley will bolt to.
Here is the one we use most often.
http://www.exoticperformanceplus.com....html?item=455
Here is the crank pinning kit.
http://www.exoticperformanceplus.com....html?item=458 Bob
Old 02-17-2008, 06:13 PM
js2fst's Avatar
Thanks I thought I might have found a deal on one.
Old 02-17-2008, 07:09 PM
EPP
EPP's Avatar
Thumbs up
Not a problem, I have not found anything else that works and the ATI balancer is the best balancer on the market, which is a plus for your engine's well being. Bob
