New Block for 500rwhp
So i blew the #8 cylinder wall and piston/rod to bits in my car. So now its time for a new build up. I don't know much about engine internals but have been reading alot on here. I am looking for 500rwhp NA and about 600 on spray
My question is what is the best/strongest/cost effective block to get for 500 rwhp?
I want to make it an easy install, not sure if the LS2, LS6, or LS7 have the same mounting points???
LS1 Tech Administrator
Most cost effective way to 500 rwhp (with strength) is with cubes. Use an iron 6.0L block, bore it .030" and use a 4" stroke. This will give you 408 cubic inches. Next, you'll make your 500 rwhp goal easier with a higher flowing intake manifold on top of your ported heads (but the LS6 intake can still do it). You'll also need something in the way of a 240/244 112LSA cam.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
I Would Like To See Someone Do A 6.2 Block With A 4.100 Stroke, Trick Flow Heads And A Cam Stated Above Just To See What It Will Do. But For Your Goals I Would Trust Patrick G About Engine Setups. He Knows Way To Much.
This is certainly a great approach to making power, but it will cost twice as much as the iron block approach using the heads and intake he already has.
__________________
Patrick gave you some of the best advice.
