Need suggestions on tire selection (MT 18" DR)
Old 02-17-2008, 10:28 AM
LS1Tech Sponsor
Superman09's Avatar
Default Need suggestions on tire selection (MT 18" DR)
Hello, I'm going to have my rim's widened out i decided and am trying to decide between 2 tires. Car is a street car and the same wheel/tire combo will be driven to the strip and raced on. Basically its a battle of tread width vs sidewall height.
305/35/18 vs 315/30/18
Obviously the 315 is a tad wider, but the 305/35 comes in at about 26.5" and the the 315/30 at about 25.5".
So basically its the little bit of extra tread width vs the .5" sidewall height difference. Which would you go with? Which do you think would hook better?
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 02-17-2008, 07:42 PM
ls2 bait's Avatar
id go with the 305/35. it will help load the turbos and give u a bit more sideall for better traction.
Old 02-17-2008, 09:40 PM
52172's Avatar
exactly
