Gen 3 with LS1
Gen 3 with LS1
82 Camaro with 346 LS1 PG trans with1.80 gear set. PTC 9" converter stalls at 4400, 4.30 12 bolt, 750 HP carb with super victor intake. Comp Cams .612 .615 Camshaft. R" Lifters, probe Pistons , MLS gaskets, Ported Pump with shim, H beam Rods, Stock Crank, Balanced assembly, Looking to spray 300 or so to go 8.70s at 3000#. Stock mildly ported heads with Ferrea Intake valves and Titanium Exhaust valves. Patriot spring and setup. Shaft Rockers PRW with 7.170 pushrods with restrictors! What do you guys think it will run???????????????????????? I went 8.80s with an aluminum rod bbc 427. Nothing special but a bunch of junk parts!!!! 1.750 Headers custom headers. Let Me know what you guys think!!!!! I am open to critisizm!!!! Thanks!!!
I think your car is awesome!! I'm in the process of doing the same build. I don't think I will run 8's but, I will be happy with 9's. Keep up the good work and keep the pics coming.
I am in the process of building a reverse cooling system for the motor right at this time!!!! I am using a Jegs sbc pump and modifying it to work . I also built plates to cover the water pump holes so I could at an fittings to the front of the block!!!! I think it will be pretty neat when it is done!!!! What headers are you going to use? After I get done with the cooling system, I have to start on the headers>
I used the Hawks Third Gen headers. They are 1.75" tubes and I opted for the 3" collector. I think for a 346 with just a plate that should be big enough. We'll see soon. By the way, where did you get that motor plate and mid plate?
i plan on swapping in a 383 into my 92 rs, but ive been looking latley and just might throw in a lsx and a t56 been reading alot about it and know how to do it all, i just cant find a nice motor and tranny lol
I am in the process of putting a 6.0 lq9 into a 64 chevyII with a Carb. I bought the victor Jr intake and Msd 6010 setup, I just ordered a blow proof ultra bell for the th 350 since mine was cracked and the trans was still good.
my car weights 2150 or so with out driver( it was 2300 with big block with Iron heads) and Looking for low 10's on motor with an f14 cam with stock heads. I am going to get custom headers since I cant find a set already built so to get it started for now I will be putting on a set of Manifolds off the CTS-V caddy. They are a shorty header design so I should be ok untill I get headers built. If I run low 10's with them, they may stay
Good luck with your build, I hope it runs what you expect.
I have finally put the engine in for the last time. Put all the bolts in the bellhousing, which are extremely close to the floor/tunnel, painted everything all up and still working on the cooling system. With the 1/4 front plate it causes all kinds of problems as far as the belt lining up on the WP. I had a sbc meziere pump that I modified and installed 8an fittings to go to the top holes on the motor and 10an fittings to go to the bottom holes. The hoses are not very long as I have mounted the pump under the radiator. I made adapter plates out of 1/4 aluminum plate to go in place of the water pump. This will also be a reverse cooling system. I am anxious to get this part done and start working on the headers. I will post pictures soon.!!!
