Where can I find a calibration table for a stock Z06 MAF?
Old 07-14-2003, 10:31 PM
Freak's Avatar
Default Where can I find a calibration table for a stock Z06 MAF?
Got a Z06 MAF but I dont want to put it in till I can flash the PCM with the correct data for it.
thanks
Old 07-16-2003, 01:19 AM
2001CamaroGuy's Avatar
Default Re: Where can I find a calibration table for a stock Z06 MAF?
this came off of a stock 2001 Z06 MAF file that I pulled from LS1Edit.com......
compared to the LS1 MAF table, The Z06 MAF is the same below 1500 Hz, and then has lower values all the way till the very last entry at 12000 Hz, yet it "should" be flowing more than the LS1 MAF.....anyone have an idea why this might be.......
you may have to fudge and fill some places when you put it into your f-body PCM.....(not sure)...hope this helps.....
Hz = flow Gm/sec
750 = 0.39
800 = 0.41
850 = 0.44
900 = 0.46
1000 = 0.50
1050 = 0.52
1100 = 0.54
1150 = 0.56
1200 = 0.58
1250 = 0.60
1300 = 0.62
1350 = 0.64
1400 = 0.66
1450 = 0.68
1500 = 1.42
1625 = 1.76
1750 = 2.10
1875 = 2.48
2000 = 2.86
2125 = 3.70
2375 = 4.18
2500 = 4.71
2625 = 5.31
2750 = 5.97
2875 = 6.68
3000 = 7.43
3125 = 8.23
3250 = 9.08
3375 = 9.97
3500 = 11.93
3625 = 13.05
3750 = 14.27
4000 = 15.59
4125 = 16.98
4250 = 18.47
4375 = 20.05
4500 = 21.72
4625 = 23.48
4750 = 25.34
4875 = 27.28
5000 = 29.34
5125 = 31.48
5250 = 33.74
5375 = 36.11
5500 = 38.62
5625 = 41.30
5750 = 44.17
5875 = 47.20
6000 = 50.40
6125 = 53.77
6250 = 57.30
6375 = 61.01
6500 = 64.88
6625 = 68.91
6750 = 73.12
6875 = 77.47
7000 = 81.97
7125 = 86.63
7250 = 91.45
7375 = 96.43
7500 = 101.59
7625 = 106.90
7750 = 112.36
7875 = 118.01
8000 = 123.83
8125 = 129.84
8250 = 136.05
8375 = 142.48
8500 = 149.13
8625 = 155.98
8750 = 163.06
8875 = 170.38
9000 = 177.92
9125 = 185.70
9250 = 193.73
9375 = 201.52
9500 = 210.52
9625 = 219.30
9750 = 228.34
9875 = 237.64
10000 = 247.23
10125 = 267.16
10375 = 277.56
10500 = 288.25
10625 = 299.25
10750 = 310.55
10875 = 322.20
11000 = 334.16
11125 = 346.49
11250 = 359.16
11375 = 372.22
11500 = 385.66
11625 = 399.51
11750 = 413.77
11875 = 428.45
12000 = 443.60
Old 07-16-2003, 10:55 AM
minivette's Avatar
I found this on the Corvette Forum. http://www.minivette.com/temp/C5MAF.xls
Old 07-16-2003, 10:34 PM
Freak's Avatar
holly crap thats a long list. thanks guys.
I didnt even know there was an LS1edit.com, Im way behind
EDIT: was thinking about what you said about the Z06 having lower numbers but flowing more. since the hole in the Z06 is bigger, the same amount of air would flow through it slower than the stock MAF, but I dont think the internals are any different, so that same amount of air would look to the MAF itself to be less, the MAF table determines how much air is going through the MAF, this is the big reason I wnated to make sure I had an acurate table. I belive thats the same reason the larger MAF ends lean the car out. The maf will read a certain freq, but since the hole is bigger there is more air going in than the computer thinks.
