No oil pressure to rockers
I am new to this site so bare with me...
I have an 04 5.3L with <30k miles. It was running good with a slight tap...It came from a wrecked Tahoe and can't seem to get any oil to the rockers. We put a new oil pump, no luck. I pulled off the sending unit on the back/top of the engine and oil flows good there. Ran a 50/50 oil & flush in case the engine sat for a while and something was clogging it and still no luck. pickup screen looks clean and so does the oil. Engine looks new when I pull the oil pan & valve covers.
Any other suggestions?
Thanks in advance,
Meatloaf
Thanks in advance,
Meatloaf
oil pump is new and I have not checked the o-ring for kinks or damage. I just reused the same one when replacing the pump and I might have messed it up when I tightened the pickup tube to set it in place. As for cranking it over, about 30-45 seconds continous.
Pardon my ignorance here, but something as simple as the o-ring could cause this problem? Why am I getting oil to the top of the engine at the sending unit but not the rockers? Regardless, I will go buy an o-ring today and try it. Should I get this at the dealer or is there something better out there?
It takes my engine atleast a half a minute for it show oil spilling on the rockers and this is with it reving at 2000 rpm. Maybe you are not running it long enough for the oil to show?
I know there is pressure at the sending unit because I took it off (since my gauge died) and oil is flowing there. I will get an aftermarket gauge later today. the oring is red/orange.
