smoke on start, rough idle, ticking. help please.
ok guys,
Since i have had my heads and cam and fuel system installed ive noticed that the car will have a rough idle on start and smoke a whitish color smoke. As soon as the RPMs get stable, and its warm (3-4 mins), the smoke goes away. Also there is something coming out of the exhaust.Looks like oil maybe. Once its warm that stops too. Another thing is the ticking. When idleing or driving i can hear a ticking sound. could it be from the cam? or do i have bigger problems? It runs perfectly normal, and pulls hard after its warm. Mods are as follows:
-stock block
-PRC Stg 2 LS6 heads
-TR230 cam
-LTs
-Catted Y-pipe
-Fuel pump and 42 LB injectors
-ported LS6 oil pump
-OEM gaskets
-Comp 918 springs
-7.4 TR pushrods
-tune using hptuners
Any help would be appreciated guys, I would like to solve this ASAP
-stock block
-TR230 cam
-LTs
-Catted Y-pipe
-OEM gaskets
-Comp 918 springs
-7.4 TR pushrods
The ticking is probably loose rocker or not the correct length pushrods. The "stuff" you see shooting out from your exhaust is probably condensation (looks black because its mixed with "soot"), which means you're runnin a bit rich. Where is the white smoke originating from?
Same exact thing here, I have a larger cam/built bottom end. I was just thinking condensation/rich soot and the white smoke being a little oil. (I have a nitrous gapped motor so I figured it used a tad bit until it warmed up)
???Maybe it's a hawk thing???
