hawk pads?
hawk pads?
are the hawk pads matched with stock rotors a good combo?? ive heard hawk pads raved about so im wondering what u guys that are running this setup think?
They are pretty dusty. I dont drive my car much and one time it was around freezing and misty. The car felt like it didnt want to stop until I warmed up the brakes. I also have powerslots on as well.
rotorsonline, strano, and many other sponsors sell the oe replacement brembos
I purchased mine from rotorsonline cause they can zinc plate them for 8 dollars a rotor
otherwise brembo sports are nearly double but they are slotted and/or drilled
the zinc plating helps prevent rust, the blanks do not come plated normally
LS1TECH Sponsor
Taking a minute to sort through what's been said:
If there is nothing wrong with the stock rotors (nor warped, not worn out), don't change them. I do have Brembo, as well as some others if you need rotors.
I sell a LOT of Hawk pads, and I use them on my car. Yet again I see folks saying how dusty they are. HP Pluses are terribly dusty (also hugely powerful), but HPS's aren't what I'd consider dusty. They aren't spotless, but most pads that stop won't be. And the dust you do get wipes off easily, and it's a light gray vs. the crap brown from OEM GM pads. I'm not sure what these guys have, or what they consider to be dusty, but I wish they'd say because it just turns folks off without any specifics.
You can find my brake parts for an LS1 here: http://www.stranoparts.com/searchbym...D=17&ModelID=7
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Moderator
I have the HPS pads with cheap slotted/cross drilled rotors from the WS6 store. The dust is a lot less than my stock set up was.
As said, you can reuse the stock rotors, just get them resurfaced.
I have the hawk hps pads with the ws6 store rotors and I would say they are better then stock, yet I somewhat wish that I went with the brembo blanks sometimes too though
