Steering column
Old 02-19-2008, 01:26 PM
95TXTA's Avatar
Default Steering column
Ok this may be a dumb question but I have never ran into this issue and had to look into it. My TA is geting a good amount of play in the steering and I am planning to get it fixed.
Someone mentioned to me they heard the LS1 cars came with a better setup and I should find one to replace mine.
I always thought they had the same thing. If this is not true any suggestions on any good after market setup's or just go OEM? The car is used as a daily driver and ocassional fun at the track.
Old 02-19-2008, 01:41 PM
96lt1m6's Avatar
it's normal wear and tear the do loosen up,look in the yellow pages for column repair,it can be repaired ....
Old 02-19-2008, 01:45 PM
porksoda's Avatar
Could be the rag joint. LS1's have a coupler and so the rag joint is eliminated. I don't know if they will interchange though. I'm thinking about buying this: http://www.unbalancedengineering.com/Camaro/Rag_Joint/
Old 02-19-2008, 02:08 PM
95TXTA's Avatar
Not bad, looks pretty simple to switch but probably a pain to reach.
About how much does that run?
Old 02-19-2008, 02:10 PM
96lt1m6's Avatar
if it is the lower section of the column then yes the rag joint could definately be the source of the problem.......
the Ls1 lower column/shaft is a more solid unit...
Old 02-19-2008, 02:11 PM
porksoda's Avatar
They are $36 then like $5 for shipping. I think the stock rubber rag joint is riveted in so it would be easier to pull out the whole thing to drill out the rivets.
Old 02-19-2008, 02:12 PM
96lt1m6's Avatar
F-Body Rag Joint Eliminator (1993-1997) $36.00 USD
Old 02-19-2008, 03:02 PM
95TXTA's Avatar
Wow, I thought this was going to be a much more expensive repair. Any special tools involved for this?
Also so if I understand you correctly 96LT1m6, the LS1 column is interchangeable?
Quick Reply: Steering column
