which HIDs??
which HIDs??
anybody running the ebay HID kits??
these are with xenon bulbs for 75 bucks shipped
these are 70 bucks shipped
i cant justify spending 250 for HIDs if i can get comparable ones for 70 freakin bucks
you can choose the temperature of your bulbs from 4300k to 12000k
what are your thoughts?
thanks in advance
thanks in advance
You can't expect that kit to last at how cheap it is. It's better to buy OEM components because they are of higher quality and known to last. The kits are a crapshoot no matter really what you spend.
If you are set on getting a kit, I wouldn't go above 6000k. The color may look cool to you but it the output only gets dimmer the higher in temp you go.
-brian
-brian
I recently bought a daily driver(honda),and im looking into to getting hid's for it.This kit caught my eye http://www.b20vtec.com/forums/top-sp...p-shipped.html
this kit was 99 shipped and the ballast were like the size three credit cards stacked on top of each other, yes the corners look ugly but they are on their way out, this is 8000 temp output at first when you turn them on the look almost blue but after they warm up they turn like a bright white color. this is my friends car by the way, the pic is comparing he supposedly badass sylvania superstars...
-brian
-brian
It's always better to buy OEM stuff. The problem with the $70 ones is that they might be DOA. Which means you can send em back but it's a PITA. I have $70 in my civic and they have been chuggin along strong for a couple months. I can tell the ballasts are poorly built but it was more of a joke than anything. Then I have a $250 set in my fog lights on my trans am and only one ballasts works. Nathan is taking care of it but it was dead when i got it. I have OEM philips in my headlights and even with my wiring all fucked up they still worked!
Kits are kits...enough said. A $70 can work ok and so could a $400 kit, but it can also go the other way.
As far as warranties go, many of the people that I know that have had kit issues have had a hell of a time getting replacement components. When they could get replacement parts they wasted money shipping components back and forth.
It just isn't worth it in most cases but that isn't to say that all of them don't work. Many obviously do.
I actually used to have a kit in my car and it worked flawlessly, but it doesn't even compare the quality and performance of a proper lighting retrofit.
