For those LT1s with aluminum driveshafts
Old 02-19-2008, 10:07 PM
HoLLo's Avatar
Default For those LT1s with aluminum driveshafts
When you installed the aluminum driveshaft, do you feel any performance difference?
Old 02-19-2008, 10:18 PM
94Z28-MSTGKLR's Avatar
No. I installed an aluminum driveshaft in my old 95 z and I didn't notice a thing.
Old 02-19-2008, 10:25 PM
Schweet97Z's Avatar
I wouldnt install it for a performance gain, but rather to get rid of the annoying vibration you receive with the stock steel peice. And like the above poster said, you wont notice any gains. Just a smoother ride at higher speeds
Old 02-19-2008, 10:27 PM
Ironxcross's Avatar
thats exactly why i did it, just because i wanted to cruise at 100 mph without a vibration is a good enough reason for me!
Old 02-19-2008, 10:29 PM
HoLLo's Avatar
Maybe i just dont pay attention to the vibes because i'm unfamiliar. Well, then how noticeable is the vibration loss?
Old 02-19-2008, 10:55 PM
SLawson86's Avatar
didnt feel a difference, but i guess my stocker was still balanced... got an aluminum for free, so couldnt hurt
Old 02-19-2008, 11:00 PM
infinitebird's Avatar
it all depends on how bad your stock one is.
Old 02-19-2008, 11:51 PM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
You would definitely notice the vibration. On my car it seemed to start around 75-80 mph. I'm going to replace my driveshaft. I just have to decide with what. I wish I would have been aware of the TSB back when it might have made a difference.
Old 02-19-2008, 11:59 PM
mhayes2344's Avatar
I too installed an aluminum driveshaft just to get rid of the vibration the stock DS had...it started at 75-80mph....and at higher speeds with the poly trans mount...it was unbarable.
Old 02-20-2008, 01:34 AM
I had the same deal on my last car, by 80 it was really bad.
Old 02-20-2008, 04:56 AM
branland's Avatar
I replaced mine before I installed the turbo and I thought I felt a slight difference, but it was probably the placebo effect. Anytime you reduce rotational mass there should be a slight performance gain of few HP. But I too, did it because of the vibration.
Old 02-20-2008, 06:47 AM
BOLO's Avatar
Most people replaced the driveshaft because of vibrations occuring at higher speed.Some for for weight reduction, others for strength(brutal drag racing launches).
Old 02-20-2008, 07:03 AM
Village Troll
SS RRR's Avatar
Believe it or not, there was a recall for this very problem and the solution was to replace steel driveshaft with a 1LE. Only those cars retaining a GM warranty were honored.
Old 02-20-2008, 08:00 AM
James Montigny's Avatar
http://www.ws6.com/mod-1.htm
I've installed aluminum shafts on quite a few Fbodies over the years.
Increase in HP is minimal at the top end, but the reduced weight and lack of vibration at highway speeds is awesome.
Old 02-20-2008, 08:41 AM
qwickLT1WS6's Avatar
it has been dyno proven for 1 horse, and a few lb. feet of torque
but the reduction in vibration is amazing its like a whole new car w no vibrations above 90
Old 02-20-2008, 09:40 AM
lmao, you can't "dyno prove" something for 1 horse. That small of a change can be seen with no modifications.
Old 02-20-2008, 11:02 AM
qwk93ta's Avatar
I feel a performance gain, but the vibration got a lot better.
Old 02-20-2008, 12:26 PM
Javier97Z28's Avatar
Until you snap that dinky aluminum shell-cardboard filled driveshaft in two...
Old 02-20-2008, 05:03 PM
BTC
BTC's Avatar
Has anyone ever run the aluminum Lingenfelter driveshaft?
Old 02-20-2008, 08:13 PM
Smokinlt1's Avatar
I did it for the vibe issue as well. Didn't notice any performance gain. I wish I could say I did but I can't. I will say it felt like a new car at 80mph.
Quick Reply: For those LT1s with aluminum driveshafts
