Has anyone mixed and matched TNT jets?
on a TNT wet set-up, mixed and match the 75, 100 and 150 shot jets?
Let's say: 75 jets (both nitrous and fuel) on one side and 100 jets on the other (does this equal an 87 1/2 shot?)
or 100 jets on one side and 150 jet on the other side (does this equal an 125 shot?)
Would really like to know as I have never heard of a 125 shot TNT wet jet.
Thanks
David
Thanks
David
Re: Has anyone mixed and matched TNT jets?
I think what he wants to know if its safe to run say a 200 shot in one nozzel and a 250 in the other nozzel. I would also like to know this.
unless you're running a true dual stage hit, w/ 2 solenoids and fueling to compensate, i'd strongly advise agianst it. you might as well just put a set of 250 jets in if you want to spray that much.
Actually I was trying to make a 125 shot.
If you really think about it, on the TNT set up, on a 100 shot each side (because of the 2 nozzle set up) makes 50 shot (each side has a fuel and nitrous jet).
So if one side is 50 (on a 100 shot) and the other side 75 (on a 150 shot). Wouldn't this equal 125?
Since the spray is mixed just before the throttle body, wouldn't it mix as one?
Not sure I'll try it until I can do it on a local dyno.
David
David
