best P/A for ls powered small AWD suv?
Old 02-20-2008, 12:25 PM
MIGHTYMOUSE's Avatar
Default best P/A for ls powered small AWD suv?
this would be on a very street friendly stock ls engine in a 3900# automatic trans all wheel drive vehicle.
positive displacement blower (need to be reminded of the options)
OR
t-76
the reasons i'm even considering the blower is because of the snappyness it would provide for stop and go traffic, in addition to the ability to have one without worries of hood or cowl clearance problems
i would stick around the 600 awhp mark to keep the stock engine alive long as possible.
Old 02-20-2008, 12:55 PM
coop5885's Avatar
you might PM Dubnali on here. His DD is a Denali(AWD) with a D1 on it, i know its a centri blower, but its a start
Old 02-20-2008, 12:58 PM
Websy21's Avatar
Why not a rotary, would make some really nice torque to get that train rolling. Plus the awd it would stick and haul too! I am curious what you decide on Dave, this would be a fun toy!
Old 02-20-2008, 01:10 PM
ABeasst's Avatar
what is this an equinox?
Old 02-20-2008, 02:34 PM
not interested in a centri blower
Old 02-20-2008, 02:47 PM
smokinHawk's Avatar
how can you think anything other then a turbo.
Old 02-20-2008, 02:52 PM
Chiet_SS's Avatar
Agreed, Have you thought about doing something with a 60-1 or a 72mm?
Old 02-20-2008, 03:12 PM
RAACCR's Avatar
David,
In the application I believe you are referring to, you'll be very challenged by the exhaust plumbing, especially on the driver's side. Custom fabricated long tube headers for the blower would be a nightmare. With that consideration in mind, a larger turbo positioned on the passenger side, or smaller twins (so you can get past the propshaft) are most appealing. I'm not sure if you've coil-overed your front end, but that gets rid of the torsion bars and opens up a bit more clearance for the exhaust.
Rob
Old 02-20-2008, 03:14 PM
if i go turbo it would be a t76 for certain, best bang for buck out there
its an auto so if turbo would not worry about spool time.. but no turbo will give the tip in response of a roots/screw blower.
Old 02-20-2008, 03:17 PM
thanks for the heads up rob.. it is a very good point i hadnt considered headers needed on a s/c application, but i fathom if all else failed i could Y the exhaust ahead of the engine as if i was doing a turbo exept not have one, merge at the passenger side front and head on out the passenger side
Old 02-20-2008, 03:30 PM
RAACCR's Avatar
David,
LS2/LS3 C6 'Vette manifolds look promising for twins if you flip them upside down and facing forward. (Depending on your accessory set-up, CTS-V manifolds might also work in the same configuration.) Hydroboost brakes, aftermarket steering shaft and coil-overs should buy you the clearance you'll need without tons of fabrication. You can "Y" the exhaust under the bellhousing and run a single exhaust along the passenger side, or snake a dual along the driver's side past the transfer case like JS did on his TY. (SY requires relocating the fuel tank for duals.)
Rob
Old 02-21-2008, 02:01 PM
well i have officially posted an asking price of $5k for everything out of the truck. If i can get that I think i will be able to afford the ls swap (stock) and the power adder.
Old 02-25-2008, 04:58 PM
anybody got links to the pricing for the positive displacement blower head unit/intake assemblies?
kb/whipple/magnacharger? whoever...
Old 02-25-2008, 06:22 PM
Coal Mining Director
onfire's Avatar
Ed Potter at Late Model Speed would be a good Magna $$ contact.
Old 02-25-2008, 06:27 PM
MTN_Z's Avatar
Your going ahead with lsx power on your Ty huh? I can't say I blame you. I have thought about doing it with my Sy as well.
Old 02-25-2008, 07:30 PM
BoostnTBSS's Avatar
Kenne Bell !!!!!!
Old 02-25-2008, 08:56 PM
Z06PSI's Avatar
Yep....
Old 02-26-2008, 05:32 PM
BoostnTBSS's Avatar
Ya would be a fun ride with a LSX in a typhoon!!!!!! At 5150lbs my TBSS is a blast!! with the 125 shot 1st gear is useless just spins all 4!!!! i never got a chance to run it at the track but i have yet to loose on the street racing low 11 sec cars.... def wanna see some pics..
Old 02-26-2008, 10:14 PM
wow thats heavy. my truck weighs the same as my car at a bit under 2 tons
Old 02-27-2008, 05:53 PM
BoostnTBSS's Avatar
ya super heavy lol!!!!! but with no bottle it ran 13.3@ 101 not too bad..
Quick Reply: best P/A for ls powered small AWD suv?
