Tools & Fabrication - isky fly cut tool, which one?
KMStevens
07-15-2003, 10:47 PM
looked at isky's website, theres 4 different pilots and like 15 different cutting wheels, which one do we need for 5.7/5.3 heads?
Louis
07-15-2003, 11:25 PM
If you are going with stock valves, the 2.060 cutter will work.
If using a 2.02 valve, get the 2.100 cutter.
We have used the 2.060, and the 2.100 cutters, and the latter works best :)
Louis
KMStevens
07-16-2003, 03:12 PM
sweet, thanks a lot!! another question, will it hurt to use the 2.100 for now with stock valves, i plan to upgrade later on...
Louis
07-16-2003, 04:50 PM
not at all :)
The JEs, Diamonds, Weiscos all come with a 2.100 relief.
willyfastz
10-28-2005, 03:09 PM
I can not find the tool yall are talking about, do you have a part # for it?
willyfastz
10-28-2005, 04:06 PM
Never mind guys I found the tools I needed and I'll post the link in case any of yall need soomthing like this. The guy was really helpful and didn't mind answering all my questions.
http://www.etsupply.com/edgetools/index.html
Look under the In Head Piston Cutters
Louis
11-01-2005, 09:57 AM
Isky has the cutters separate from the stem adapter, so it might be a little confusing. For those of you wanting to flycut on an LSx motor, we rent a dummy head with the cutter for about the same price as just the cutter alone. We charge X amount, and refund 75% of it back when we receive the tools back :)
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
