info on valve cover grommets
Old 02-21-2008, 09:04 AM
MIGHTYMOUSE's Avatar
Default info on valve cover grommets
gm part number? this for 99+ center bolt covers.
sold by the set or each? any sponsors have a set in stock?
thanks
Old 02-21-2008, 10:02 AM
itslow's Avatar
If you're wanting a grommet for the PCV fitting in the driver's side valve cover, it's a standard item that can be picked up at any auto parts store.
The molded gasket that seals the valve cover to the head is P/N 12560696, sold individually.
Someone else will need to provide the part number for the small bolt-to-cover seal.
Old 02-21-2008, 10:17 AM
99blancoSS's Avatar
or is he talking about the sleeves that the bolts go through
Old 02-21-2008, 01:51 PM
excuse me yes the grommets around the screws is what i need please.
Old 02-21-2008, 03:20 PM
massls1guy's Avatar
old #12559893,
REPLACED BY #12577215
http://www.sdparts.com/product/12577...oltM60x10.aspx
The part number is the bolt and it's supposed to come with a grommet. Not sure about the grommet by itself.
Old 02-21-2008, 04:22 PM
dam will be major suckage if i gotta buy the bolt to get the grommet.
thanks for the link
Old 02-21-2008, 04:28 PM
99blancoSS's Avatar
Is that 3.67 peice? 30 plus delivery..ouch
Quick Reply: info on valve cover grommets
