what oil do you recomend for a 383 stroker, sts rear mount?
Old 02-21-2008, 02:09 PM
wwmost's Avatar
Default what oil do you recomend for a 383 stroker, sts rear mount?
im either gonna get 5w30 mobil 1 or the german castrol 0w30. what wuold you recomend? is ther anything i should know about oil with a turbo?
Old 02-21-2008, 02:55 PM
cablebandit's Avatar
rotella 15/40
Old 02-21-2008, 04:29 PM
ZL1Killa's Avatar
mobil1 5w30 with some tufoil
Old 02-21-2008, 09:58 PM
wwmost's Avatar
tufoil?
Old 02-21-2008, 10:07 PM
gametech's Avatar
I run Castrol 5/50 syntec in my supercharged 4.8 work truck, but I only have 246000 miles, so I don't know how well it holds up to really high mileage.
Old 02-21-2008, 10:34 PM
wwmost's Avatar
what do you think about rotella t in my rear mount? would that be to thick to travel back there?
can somone explain to me what thickness of oil i should pick? why i should pick different ones for the climate? i live in jersey. the car only comes out when its nice, otherwise it stays garaged.
Old 02-21-2008, 11:02 PM
gametech's Avatar
We all have our personal favorites, but the truth is if you use modern multi weight oils designed for gasoline motors, the only way to really go wrong is Quaker State. You would be hard pressed to find anyone here (the FI forum) who has had an oil related engine failure. Most have some sort of "ran the motor too damn hard" failure long before the oil is an issue.
Old 02-22-2008, 12:01 AM
wwmost's Avatar
im leaning towards the rotella t. what do you recomend? regular 15w40 or synthetic 5w40? the new motor has about 10k miles on it. im just more worried about the oil getting to the turbo fast anough
Old 02-22-2008, 12:52 AM
'00SLVRDO's Avatar
i'm running a 408 w/sts turbo and use mobil 1 15w50 synthetic
BTW, i used rotella 15w40 during the break-in
Old 02-22-2008, 07:09 AM
wwmost's Avatar
is rotella used mainly for breakin? ive heard that their synthetic was pretty good. what is the best synthetic you can get out there? besides amsoil and redline.
Old 02-23-2008, 03:43 PM
wwmost's Avatar
bumpp
Old 02-23-2008, 03:49 PM
THENASCAR's Avatar
never use synthetic blend or synthetic during break in. just normal thicker weight oil for break in
Old 02-23-2008, 03:51 PM
wwmost's Avatar
my motor has 10k miles on it. so im looking for a good synthetic with my sts setup. is rotella t synthetic good? if not what would you recomend? what weight oil should i stay around. for summer weather in nj.
Old 02-23-2008, 04:06 PM
52172's Avatar
I just picked up a few gallons of Rotella 5-40 full synthetic at walmart for only 16 dollars per gallon.
Old 02-23-2008, 04:15 PM
wwmost's Avatar
so im guess that oil is decent?
Old 02-23-2008, 04:42 PM
52172's Avatar
its better than decent I have heard nothing but good things about it and the price is right.
Old 02-23-2008, 05:34 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
rotella has only been in my 383.forcedinductions.com and Comp Cams swears by it.its cheap has a great additive pack and theres a synthetic version as well.
Old 02-23-2008, 05:44 PM
wwmost's Avatar
i guess rotella it is.......... hopefully my wal mart carrys it.
Old 02-23-2008, 05:52 PM
vandal0-0's Avatar
I have a 408 and a STS and I run the Rotella oil.My friend is a deisel machanic for Schnucks grocery stores here in St.Louis and thats what they run In all there trucks,and they dont change the oil In those trucks very often.He also runs it in all his vehicles.
Old 02-23-2008, 09:55 PM
wwmost's Avatar
how would my car perform differently with 5w40 compared to my 10w30 i have int here now.
Quick Reply: what oil do you recomend for a 383 stroker, sts rear mount?
