MAF in front of ProCharger question
Do you NEED to connect the bov into the system when running the MAF in front of the blower? My old setup, MAF after the blower, I had the bov just venting to the atmosphere. I was told the bov needs to vent back into the system as to regulate the air correctly for the MAF.
Any comments or suggestions with this?
The computer is depending on the notion that every bit of air going thru that MAF is going straight into the engine. The computer has no way to know that the surge valve (bov) is placed in between the throttle body and the MAF.
As such, the computer is going to think the engine is ingesting all that air you are bypassing and add the appropriate amount of fuel.
In short, the inlet tract between the throttle body and MAF CANNOT have any leaks or surge valves (bovs).
I'm used to understanding a MAF when it's in stock configuration. This is a new concept to understand with the MAF in front of the blower and comprehending how the air travels within the blower system. It's a learning curve like anything else.
bov? What is that? I have the same MAF placement on my car and i notice that a lot of times that the check engine light will come on when i go WOT and let off really fast. Is there something that i need to move?
LS1TECH Sponsor
BOV=Blow off valve, do you have yours venting to atmosphere?
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
LS1TECH Sponsor
__________________
