Should i assemble it myself?
Well i'm about to purchase a Compstar 383 Speedpack. Everything comes balanced and ready to be put in. My question is should i put everything in myself or have a machine shop do it? I really want to do it myself so i can gain the experience, but i also want the thing to last for a while and not break due to poor installment on my part. Tell me what you guys think.
Your going to have to have the block machined fvor the clearances of the stroker kit. Even though it is balanced your still going to have to have it rebalanced after installing it into the block. Its not something you can just throw in and your done. There are clearances, tolerances, and other measurements that need to be dead on or your going to ruin a perfectly good rotating assembly or even a perfectly good motor.
hell yes you should!
just have somebody stand by and help to make sure that everything is right. like 9formula4 said their is a lot to double check when your block comes back for the machine shop.
but yes you should, i think everbody that wants to even talk cars should have put a motor together.
You can put it together... grind here and there for the stroker ("machine" is a little bit of a extreme word).. Make sure it rotates without ANY binding. Paying someone to clearance it for the stroker wouldn't be very $$ though.
Assembly. Make sure all ring gaps are right. Make sure the pistons are in the hole right. Plastigauge EVERYTHING. It's cheap and the time is yours (so free) so use it to make sure everything is right.
No reason you couldn't do it yourself except maybe putting in cam bearings.
^Good call on the Eagle/Scat stuff. The parts are usually pretty good aside from a bad apple here or there, but I wouldn't recommend ever buying their balanced rotating assemblies. You're much better off to buy the rotating assembly unbalanced and have a trusted machine shop balance it.
I bought the "How to Rebuild Small-Block Chevy LT1/LT4 Engine" by Mike Mavrigian. It's a really good book, thats very descriptive with lots of pictures. I've already read it once and i've started back through it again
