Forced Induction - The new LS9 question
2000ramairformula
02-24-2008, 02:49 PM
I have a question about the new ls9 w supercharger. Does anyone know if that blower/intake will bolt up to a regular LS1? Just curious, it might be too early to ask that.
MonochromeSS
02-24-2008, 03:02 PM
It would require a head swap i'm pretty sure, but other than that it would bolt on. Would it fit under the hood and cowl? probably won't
ls1290
02-25-2008, 02:08 AM
The intake is designed for the LS3/L92 heads. The chances are fairly small that it will fit on a fbody.
Keith
2000ramairformula
02-25-2008, 09:23 PM
Ya but the L92 heads will bolt up to a ls1 but the bore size is too small for the valves? right?
gametech
02-25-2008, 09:34 PM
i don't know if their info is correct, but a recent HotRod article claimed that the heads are a new design. If this is true, all bets are off on interchangeability.
ls1290
02-26-2008, 02:01 AM
L92 heads need a min of a 4.00" bore. So a LS1/LS6 is a no go.
Keith
ninetres
02-26-2008, 02:14 AM
It would fit under the hood if you put a clear plastic cowl on it :secret2:
2000ramairformula
02-26-2008, 01:18 PM
Keith
Isn't that what I just said?
99SS-T
02-26-2008, 05:32 PM
You said it in question form!!
John
2000ramairformula
02-26-2008, 09:36 PM
John
Well my bad. Phamspeed turbo kit? How much did that run you?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
