MSD Window switch?
Old 07-16-2003, 07:13 PM
Need2gofaster's Avatar
Default MSD Window switch?
Where do i plug the wire that is supposed to plug into the coil at on my LS1? The rest are self explainitory.
Old 07-16-2003, 08:23 PM
Ron@Vengeance's Avatar
Default Re: MSD Window switch?
tach feed splices into the white wire, pin #10, on your pcm. Its the tach signal on the PCM itself. Located on the lower of the two bars.
Old 07-16-2003, 08:49 PM
ScottyG's Avatar
It's not the #10 white wire ..... it's different on a '98. I think the color is still white, but on a different numbered pin. Check here: http://www.ls1.com/98pinpcm.htm
Old 07-16-2003, 10:21 PM
Sorry, didnt see he had a 98. Follow the link, I dont remember the # for the 98s. Goodluck
