clutch pedal assembly
im in the middle of a swap and bought a pedal assem new off of ebay. i forgot when you buy a dealer part new they come bare w/ nothing else other than what you order. never seeing the clutch pedal assembly for our cars im not sure if i will need any springs. i know ill need the two switches and one clip for the master cyl. didnt know if there are return springs for the clutch pedal.
thanks,
corey
thanks,
corey
im doing the swap myself, and I dont want to tell you any mis information but from what I have read and heard from research on here. The LS1 pedal assembly should have a return spring and the LT1 Pedal assemblys do not.
Im not exactly sure where the spring go's I just know the LS1 Cars have one. Im sure you can find a pic somewhere around here if you do a search. I know that you will need the Master cylinder rod clip and I believe there are 2 switches for the clutch pedal and 2 for the brake. good luck
