Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
355 hp ?
Old 02-25-2008, 04:52 PM
bigtim02ta's Avatar
Default 355 hp ?
how much estimated horsepower would a 350 bored .40 with 12.1 pop up pistons, 292 comp cam advanced 6 degrees heads are 993 s with 202 160 valves shaved down with a full race port and polish with comp cam magnum full roller rockers a performer rpm airgap intake with a race demon 750 carb , holley blue mechanical fuel pump and 100 shot of no2
Old 02-25-2008, 05:22 PM
blubyou02's Avatar
Default horsepower
the cam is a little small for 12-1 compression without adding the nitrous i would guess 415-425 add bigger cam and match the cams rpm range with the heads and intake none of your parts look like they match each others rpm ranges so hell you might only get 375hp
Old 02-26-2008, 02:06 PM
bigtim02ta's Avatar
thats the cam my machinist said go with with my heads what would u suggest
Old 02-26-2008, 03:26 PM
In-Zane Moderator
ZONES89RS's Avatar
I suggest lowering the compression if you wanted to stick with that cam. Are you looking for a race car? That is track kind of compression, too much for the street unless you dont mind race fuel or running the timing way back, then it will not run optimal.
Old 03-03-2008, 04:52 PM
bigtim02ta's Avatar
well race fuel is no prob and the timing will be backed off for the no2
Quick Reply: 355 hp ?
